Connect Jira and Linear to Wave
Connect Jira or Linear to Wave to link each opportunity to the issue your team tracks it in. After you connect a tracker, you can create an issue directly from an opportunity, and Wave marks the opportunity Shipped when the linked work is complete.
Connect a tracker
Wave connects to Jira and Linear at the workspace level. You must be an Amplitude organization admin to connect a tracker. For Jira, Amplitude recommends a service account so the connection doesn't depend on an employee's personal account.
  1. In Wave, click Settings.
  2. Open Wave settings > Connected Tools.
  3. Next to Jira or Linear, click Connect and authorize Amplitude in the tracker.
To remove the connection, open Wave settings > Connected Tools and click Disconnect.
How linked issues relate to opportunities
A linked issue and its opportunity are separate objects. Each has its own status and assignees. Manage the issue's status and assignees in Jira or Linear as usual.
When a linked issue or pull request shows that the work is complete, Wave marks the opportunity Shipped and starts measuring its impact.
Each opportunity links to one tracked issue. Review the linked issue on the opportunity page.
Create an issue from an opportunity
On an opportunity page, click Create Jira issue or Create Linear issue. Wave creates the issue with the opportunity's problem, solution, and acceptance criteria, then links it to the opportunity.
Available issue destinations depend on your connections and access. Where enabled, use the Product Area's Configure > Opportunity Actions settings to turn destinations on or off.
Pause incoming issue updates
Organization admins can stop incoming updates without disconnecting the tracker. In Wave settings > Connected Tools, turn off Listen to Jira issue updates or Listen to Linear issue updates. Linked issue previews and status changes stop updating, but your team can still send issues to the tracker.
Tracker connections link delivery work. To let investigations read external context, configure the separate external MCP sources.
Was this helpful?
On this page
