Manage Product Areas
このページはまだあなたの言語に翻訳されていません。 現在取り組んでいますので、後でもう一度確認してください。
After you create a Product Area, you can change how often Wave investigates it, who owns it, and whether it stays active. To change these settings, open the Product Area and click Configure.
Change the investigation schedule
Wave investigates each Product Area on a recurring schedule, for example, weekly on Fridays.
- Open Investigation Schedule.
- Click Edit and choose how often Wave investigates the area.
The Investigation Schedule section shows the latest run, its result, and the next scheduled run. To view earlier runs, click Show history. To open a run's results, click View Run.
To run discovery between scheduled runs, open the Product Area and choose Create > Generate opportunities.
Change Product Area details
Open Overview to change the Product Area's name, description, and owner. The owner is the person accountable for the area. Only the owner can add MCP external sources to the area.
Output language sets the language that agents use for opportunities and investigation results. The default is Auto Detect.
Subscribe to a Product Area
To subscribe to a Product Area, open it and click Subscribe. Subscribed areas appear under Subscribed Product Areas in the Wave navigation.
Archive a Product Area
Archiving hides a Product Area from your workspace and pauses its scheduled investigations. You can restore an archived Product Area within 30 days.
To archive a Product Area, open Overview and click Archive.
Check usage limits
Wave limits how much each workspace can run. Open Wave settings > Usage for the active Product Area limit and the Product Area's Usage section for its run limit:
- Active Product Areas: How many Product Areas with Wave investigations your organization has, compared with its limit.
- Weekly runs per Product Area: How many runs a Product Area used in a rolling 7-day window. Scheduled investigations, manual investigations, and agent runs all count toward this limit.
To change your limits, go to Plans & Billing.
これは役に立ちましたか?
